Check engine light
Old Aug 1, 2009 | 09:53 AM
mike1's Avatar
Default Check engine light
My 2007 CX-7 has CEL on - again. Last time I paid the local mechanic $70 to hook up computer and tell me the gas cap was loose. Can anyone tell me how to turn the light off for less than $70? Thanks
Old Aug 1, 2009 | 10:19 AM
oldeng's Avatar
Best is to find out why CEL goes on and fix it. (Recent Mazdas have had a history of gas tank cap issues, usually jamming), and Mazda has replaced the original cap with a modified design; check this out.
To do a CEL reset without using a scanner, leave the door open so the coutesy light is on, then disconnect the negative battery terminal for about 30 seconds; this will clear the CEL, among other things.
Once you have done this, you will have to reset your clock and tuner presets, AND if your entertainment center has an ant-theft provision, you will have to re-enter the code to re-enable it.
You can get this code from a dealer, or you can search this forum for how to do it yourself.
pdw001
Dec 5, 2022 02:54 PM
Rockstar
Mar 13, 2015 01:07 PM
KillerTofu
Sep 13, 2014 10:35 AM
brave-heart
Apr 21, 2010 07:44 AM
stoogefan32
Jul 10, 2009 07:50 PM
