2012 brake light not functioning
Old Apr 26, 2021 | 10:55 PM
dropnine's Avatar
Default 2012 brake light not functioning
Hi,
I have an problem with my brake lights that just start today on my 2012 CX-7. The only brake light that works is the hatch brake light. The two main ones do not. The brake light switch functions, The bulbs are fine, all other lights function and the stop fuse is fine, too. I've looked everywhere for a possible solution but I cannot figure this one out. Nothing was changed in the car, they just stopped working. Does anyone have an idea of what may be happening. I'd appreciate any ideas.
Thanks,
~ c
Old Apr 27, 2021 | 06:30 AM
For piece of mind replace the bulbs. They may look fine to the naked eye. Unless you have a multimeter to test the bulbs & the bulb sockets, this is your best bet.
Old Apr 27, 2021 | 12:24 PM
dropnine's Avatar
Thanks for the idea. The bulbs have been metered and tested fine. I did go ahead and changed them, as well. I checked and there's no voltage going to them. the hatch is working, but both lower ones have no voltage - right out of the bluie. Is there another fuse inline that's hiding somewhere? I'm trying to find a wiring diagram, but without much luck.
Old Apr 29, 2021 | 05:26 AM
RHD, Japan built.
File Type: pdf
Old Apr 29, 2022 | 08:48 PM
Grimbo's Avatar
Originally Posted by dropnine
Hi,
Thanks,
~ c
I have the same issue. Did you work out what the problem was?
JENSOUZA
Apr 8, 2018 03:07 AM
schlompie
Mar 6, 2012 02:49 PM
makthenif
Jan 31, 2010 03:29 PM
Mazda3231984
Jan 30, 2007 07:06 AM
dave87
Nov 6, 2006 09:52 PM
