remote window only opens
Old Jan 4, 2026 | 07:42 PM
Doug Lassiter's Avatar
Default remote window only opens
Of course the CX-5 has a "remote window"feature, where you press the unlock button on the key fob four times, and hold it down on the last press, and ALL the windows come all the way down. I guess that's how you ventilate a car before you get in it on a hot day? Minor convenience. But the remote window function doesn't close the windows. Just opens them. So if you happen to open all the windows with the key fob, and then decide you'd rather have them closed, you need to turn on the car and close them with the window switches inside.
Old Jan 4, 2026 | 09:22 PM
schmieg's Avatar
That's to prevent remotely choking or decapitating a child or a dog. Complain to the lawyers.
Old Jan 5, 2026 | 09:31 AM
Thanks. I guess that makes some sense. Power windows can be dangerous. But Mazda's allegedly have "jam-safe" safety feature that is supposed to reverse the window if an obstruction (a hand, head, etc.) gets in the way. That being said, the manual says "Power window switches that are not locked with the power window lock switch would allow children to operate power windows unintentionally, which could result in serious injury if a child's hands, head or neck becomes caught by the window." So I guess "jam-safe" isn't really that safe?
Old Jan 5, 2026 | 11:02 AM
schmieg's Avatar
My Grand Cherokee has those "protections," but it doesn't allow remote raising of the windows either. For that matter, neither does my MX5.
Old Jan 8, 2026 | 08:59 AM
Holy crap...
I recall when you rolled the windows up and down with a crank handle and nothing ever got stuck in them unless it was on purpose.
Old Jan 8, 2026 | 09:55 AM
I guess some of you never pulled a door panel off to remove foreign material in the window transmission mechanisms before. When those old-style door window seal started to become brittle and leaves gaps in the window to door sealing then many foreign debris would get into the window tracking causing everything from hard to roll up to the limiting the full closing or opening of a window. Even on new seals foreign material can and does occasionally gets pulled into the door cavity past those window glass seal during operation the window up and down.
My guess is the rare owner of a vehicle actually clean the sealing area ever because most never think about that as an area that gets dirty.
Old Jan 9, 2026 | 03:49 PM
Well, FYI, jam-safe ONLY WORKS if the window is in automatic closure mode. That is, you pull up on the window control button quickly, and then let go of it, such that the window finishes closing by itself. If you hold the window button up to close it, jam-safe WILL NOT WORK, and you will seriously crush anything in the window. The point being that if you're holding the window button up to close the window, the car thinks you really want to crush whatever is in the window. If jam-safe sees an obstacle, it will reverse the window direction. That being the case, it takes a moment for jam-safe to do it, so you could get something big slightly crushed.
Old Jan 9, 2026 | 04:01 PM
lol I often wonder in the case of a member that joins starts several help me threads and then challenges any of the helpful responses?
Old Jan 9, 2026 | 04:49 PM
I never challenge a helpful response. I am sometimes inclined to challenge an irrelevant response.
Old Jan 9, 2026 | 05:07 PM
I have read every one of your responses started threads. Honestly you could have started one only for your one Mazda and all the service related questions for it? And that most all have been asked and answered by members years ago. So you don't seem to even look first for answers that have already been asked and answered?
Anyway you are on my list to be entertained by your threads so as long as *you never challenge my responses LOL I will continue to respond in anyone's thread to hopefully set more facts less DIY wisdom and help member's.
*long as you never challenge my responses
orion
Apr 25, 2024 07:05 PM
shahryar2002
Mar 9, 2021 10:04 AM
nealward
Jan 19, 2020 02:00 PM
thedfo
Aug 10, 2007 08:10 PM
mmiller2002
Sep 22, 2006 06:09 PM
