Plus 1 replacment rubber on a CX-5
Old Dec 21, 2019 | 01:10 PM
svtman's Avatar
Default Plus 1 replacment rubber on a CX-5
Anyone have any experience with a +1 tire replacement on a CX-5?
I have a 2018 GT with 7" wide, 19" stock rims. Plus 1 for me would be replacing the stock 225/55-19 Toyos with 235/50-19's, same rims..
Has anyone tried this?
Thanks,
Carl
Old Dec 21, 2019 | 05:00 PM
shipo's Avatar
Thanks,
Carl
A few points:
  • What you describe above does not qualify as a "Plus One" increase in tire size; that term is reserved for when you increase the wheel size, in this case to 20 inches.
  • Moving from a 225/55 R19 to a 235/50 R19 will reduce the diameter of your tires and in turn cause your speedometer and odometer to indicate faster speeds/more miles driven than actual.
  • If you feel the need for a wider tire, the 245/50 R19 will give you a similar overall diameter to the OEM tires, however, I cannot give you any guidance on whether the 245 section width tires will rub the outer fenders on a rough road or the inner fenders at full steering lock.
  • Given a 7" wide rim is the minimum spec for 245/50 R19 size tires, mounting them may look a bit funny as the sidewall will angle out from the rim flange to the tread section of the tire.
Ludy5
Feb 12, 2018 11:35 PM
ducracer
Mar 17, 2010 09:08 AM
motec
Aug 27, 2009 01:55 PM
parkmazdajon
Mar 8, 2007 05:23 PM
Minibird
Apr 22, 2005 07:49 PM
