Oil Catch Can?
Old Oct 15, 2024 | 10:54 AM
Originally Posted by Point37
thanks...that is what i am afraid of with this votex mag plug...the way it's made it looks like the rod could just separate at some point so i'm hesitant to buy this...still looking for a m14-1.5 goldplug...3k mile first oil change it is then...yes swapping crush washers is common sense...
https://votex-us.com/Mazda-cx-5-stai...er-4-cylinder/
No that is not what I was doscibing .. here is the cheap brand with a rod style
Old Oct 15, 2024 | 10:59 AM
If you had gone to my thread as I suggested, you would have seen many pictures over miles and documentation of changing oil and filter every 3 k miles.
Old Oct 15, 2024 | 11:00 AM
Point37's Avatar
votex and goldplug are built similarly...the rod is just shorter
Old Oct 15, 2024 | 11:14 AM
No they are not.... trust me I am an engineer among many other things.
Vortex uses buttons.
Button are more secure during instalation which are pressed into the threaded porttion. While rods are less expensive for the manufacture to use and often fracture which is unseen during their pressing into the drainplug.
Buttons and rods may look close to the same, but they are vastly different on how they are manufacture.
Old Oct 15, 2024 | 12:40 PM
Point37's Avatar
*Votex uses buttons.
well that makes 2 of us...i'm just not a mechanical engineer (civil)...so what you're saying is both buttons and rods are pressed into the bolt head, so same installation method...the rods are longer than the buttons obviously but is the depth they are pressed into the bolt head the same or no?...i understand that the length of the rod makes it more apt to microfractures upon pressing into the bolt head just due to the length vs a button...just curious on the depth pressed into the bolt head between the 2
Old Oct 15, 2024 | 05:04 PM
But a inexpensive rod type and put it in a vice and break it easily with a pair pf pliers and then you will understand. Don't bother with button type you wont break it. LOL
And as I said on your thread I am done talking about drain plugs. While quality is important debating and talking about every aspect of them, to what end. I know what works and does not from a straight engineering prospective and what I have used and seen fail in a few decades.
karlt10
Feb 24, 2024 10:23 AM
bobm
May 2, 2022 04:20 PM
bobm
Apr 22, 2022 03:24 PM
Alo
Sep 25, 2021 07:44 PM
mxer201
Sep 7, 2008 11:14 AM
