Mazda CX5 2013 TCS/TPMS ON
Old May 11, 2025 | 02:49 AM
brianmurindagomo's Avatar
Default Mazda CX5 2013 TCS/TPMS ON
Hi all.
I have a Mazda CX5 that is showing TCS OFF and a Sliding Car ICON on the dashboard. The car has NO TCS OFF button.
Please assist with how to turn it OFF?
Old May 11, 2025 | 06:59 AM
All Mazda CX-5 are supposed to have TCS button.
It is located on the dash near the steering wheel.
2013 CX-5 Owners Manual
Old May 11, 2025 | 09:03 AM
Old May 11, 2025 | 09:09 AM
Most Mazda models
The TCS at times will shut off from some sensor anomalous input, this is normal, and it should automatically turn off the dash light when the sensor condition changes to normal sensor input or the next drive cycle. If not, and after shutting down the engine then I recommend to either go to MAZDA or a service shop and have the problem diagnosed.
Manually turning off only control the driver choice in having it on or off during that drive only. Shutting off the engine returned the TCS to automatically on for next drive.
Old Sep 8, 2025 | 05:07 AM
Good day.
Anyone with a knowledge on how to turn off this warning when there is no button please assist. Most of the comments so far do not help.
Old Sep 8, 2025 | 07:14 AM
I have seen this posted on several forums, but I have no idea if it will work or if it will cause other issues.
Press the start button without turning the engine on, just the ACC mode. While pressing the start button, simultaneously press and hold for at least 5 seconds the panel illumination **** or until the master warning light flashes. Once the light flashes for few seconds, the ECU resets and hopefully it will make your problem go away.
Old Sep 12, 2025 | 07:45 AM
1st step is to scan for fault codes (DTC's).
orion
Feb 20, 2024 05:47 PM
marceluisupb
Mar 5, 2023 05:51 AM
Terrapin123
Sep 18, 2021 05:22 PM
looney2nes
May 13, 2021 03:09 PM
dcab1
Jul 22, 2018 10:15 AM
