Intermittently blowing grey/white smoke
Old Jan 4, 2026 | 08:06 AM
Freedom262's Avatar
Default Intermittently blowing grey/white smoke
Hi.. I have had my car for a while now and since I’ve had it, it blows smoke on tick over and sometimes tick over is uneven. It doesn’t always do it only sometimes. I have tried using the usual injector cleaners you put in the diesel fuel tank etc and it seems to improve it but would like to try and get to the bottom of the issue! The car does not loose any fluid or oil. Could this be a faulty injector/problem on the DPF system? I have previously taken it to a garage and it has behaved itself! There were no fault code’s showing in the history. Any help would be most appreciated. Thanks.. Rob
Old Jan 4, 2026 | 10:16 AM
Old Jan 12, 2026 | 01:38 PM
Chaplain Pat's Avatar
White Smoke is indicative of Coolant in the Cylinder. This can be Detected with a Bore scope through the Spark Plug holes or a Leak Down Test.
Old Jan 12, 2026 | 07:43 PM
Alexmed2002's Avatar
This is what I would want done. These diesel motors tend to have coolant issues a lot from what owners say online throughout the threads.
Old Jan 12, 2026 | 08:51 PM
Sorry I missed the Diesel part. My solutions won't work with that.
Old Jan 13, 2026 | 01:19 AM
Definitely still seems like a coolant related issue nonetheless. That's a good place to start checking.
Old Jan 15, 2026 | 03:28 AM
Freedom262's Avatar
Start checking? Where’s the best place to start? It does not loose any coolant at all. Fault is very intermittent with no warning lights on dash. Thanks..
Chowd
Sep 24, 2023 06:52 PM
salmonkin
May 18, 2014 05:04 PM
derrydundee
Jul 14, 2012 05:14 PM
carlos navarro
Nov 13, 2006 11:07 AM
lickwicker6bar
Jan 30, 2006 10:11 AM
