Front Radar Sensor Warning Message
I was out on the highway for a couple hours today in some lousy weather. Rain turning to snow and back to rain. Both on the way there and back I kept getting warnings about the front radar sensor being blocked.
I haven't seen that message before but thinking back, I maybe I didn't do any highway trips during bad weather last year. I stopped once along the way and wiped off the Mazda emblem on the front and that fixed it for a little while. Is this a common problem on the CX5? Anything I can do to prevent it from happening if I'm out and it's snowing? Put some RainX on there maybe?
Thanks. I started getting worried "is this going to happen every time I go out in bad weather?"
Same here with mud/snow/ ice, etc.
Clean it off and it's fine, the amount of cleaning obviously dependent on how much there is.
Even frost in the morning can cause the issue, but that goes away once the temp warms.
I'll have to see how it goes. It was like 33 degrees yesterday and a light mix back and forth of rain and snow. About 20 minutes into my drive I got the warning the first time and my cruise control stopped. I went on a bit until I could pull off and wipe off the sensor. It worked again for a little while and then must have got covered up again. When I got to my destination I looked again and there was a little bit of slush on there but nothing major. Hopefully this isn't something that's going to happen a lot. Not having cruise control would kinda suck.
DonN
01-25-2020 07:44 AM
