Front drive noise
Old Mar 1, 2019 | 08:38 PM
Pfestus1's Avatar
Default Front drive noise
About a month ago I bought a used 2014 CX5, AWD, with 58,000 miles. I have been loving the car since then. But today it started making a noise from the front drive train. It is a clicking or more like a rapid knocking noise from about 20 mph and up. Louder when I let off gas, diminishes when I accelerate, and goes away completely on braking. I believe it is coming from the left front axle or wheel bearing. Can anyone help with diagnosing this, and what it takes to fix it?
Thanks.
Old Mar 3, 2019 | 09:20 AM
Chris!'s Avatar
Thanks.
It sounds like you may have a constant velocity joint going bad. If there is grease on one of the flexible covers (there is one on each end of each front axle) that's probably the problem. Sometimes the covers get torn. If that's the case, most shops can install a rebuilt front axle.
Old Mar 10, 2019 | 08:58 AM
Pfestus1's Avatar
Problem resolved. LOOSE LUG NUTS!
Apparently some one did not properly torque the lug nuts on the left front wheel. Once those were tightened and torqued, problem went away. Simple fix.
Old Mar 10, 2019 | 09:35 PM
Chris!'s Avatar
While that's a bit aggravating, at least it was a cheap fix!
Old Mar 10, 2019 | 10:15 PM
schmieg's Avatar
You're lucky that you had no symptoms other than noise. A few years ago, a local Toyota dealership did not tighten the lug nuts on my 4Runner right rear wheel. The wheel came off just down the street from the dealership. They had to put a new hub and studs on and replace a custom wheel. Luckily, no other damage. To their credit, they acknowledged the problem immediately and took care of all repairs, but I was without the vehicle for a while while they sourced the wheel.
David White
Jun 11, 2018 06:57 PM
fflt765
May 25, 2012 12:52 PM
yilyas
Jun 18, 2011 09:27 AM
mickpdx
Jan 14, 2009 10:38 PM
Sploogius
May 23, 2007 02:01 PM
