CX5 T, Pedal Roar throttle enhancer
Old Sep 11, 2024 | 09:34 AM
Vegas71's Avatar
Default CX5 T, Pedal Roar throttle enhancer
Hello, new member here. I have tried multiple times now, trying to setup the unit with no success. My car has exhibited the ecu light turning on, and I can pull out of the driveway just before the car goes into limp mode. Has anyone used this brand on their Turbo model? I thought for sure that it was the time I had the car resetting the ecu by disconnecting the neg terminal. The directions stated 15 min. I tried a half hour. Maybe, more time needed?
Thanks,
John
Old Sep 11, 2024 | 02:53 PM
When asking for service advise you really need to give important information: Minimum,
miles?
exact model?
last service done?
and when was it?
Stop disconnecting the battery. You could likely cause more issues then the unresolved one!
The first thing to do is get your battery health checked
Then and only after it shows to be GOOD, you need to have your ECU scanned in all the reporting area's. BTW when you disconnect the battery it adds to your vehicle's counters until the ongoing problem is resolved.
If the scanning of the OBDII diagnostic connector is done properly there "WILL" be 1 or more DTCs! When you get them, you can post back, and members can try to advise from that point.
Old Sep 12, 2024 | 11:51 AM
RonBeck's Avatar
Thanks,
John
Try Pedal Commander. I have it installed on my '19 CX-5 GTR and love it.
Old Sep 12, 2024 | 01:17 PM
Doozy
Sep 12, 2024 01:16 PM
cshot312
Oct 4, 2023 06:37 PM
Mike Schaub
Sep 22, 2023 11:23 PM
FORTYREC
Apr 17, 2022 07:06 PM
Nissan20det
Sep 18, 2018 10:24 AM
