CX5 Diesel engine issues
Old Dec 4, 2023 | 05:42 AM
  #291
Gunnadoo's Avatar
Originally Posted by Ribbs
Hi all,
I'm not sure if this has been questioned in here or not, so please direct me to the comments if it has.
My 2015 mazda cx5 diesel has recently had its 2nd head gasket failure. Mazda Australia have just approved the repair but not a hire car. It's been 6 weeks without the car already and going off the 5 other vehicles sitting at the dealership with the same problem, I believe I may not see my car again before 2024. I live in a small country town, have 2 young children and now no vehicle. Not an ideal situation! However I am grateful the repairs will eventually be completed.
I am sus though as we were told that only the head gasket is going to be repaired. We have not been told what caused the problem in the first place. As far as i am aware, all tests have come back indicating there is nothing wrong other then a head gasket.
I've asked for the reports, but am told I can't have these as they are internal documents. I'm increasingly frustrated as I don't have answers or a vehicle. I will be contacting consumer affairs to see if there is any consumer rights I have around the time frame repairs might take.
I am also wondering if anyone in Australia has looked into class actions for this problem? It is clear that it is a recurring problem with these motors and having already had a recall that clearly hasn't solved to problem, I'm wondering why Mazda Australia are not being honorable to their customers, regardless of the number of years since the vehicle was purchased. I am the sole owner of my car and am gutted that I have had to go through this motor issue for the 2nd time. Only this time I'm feeling like I have to fight to get Mazda to fix the KNOWN problem. Having a rough estimate from what the Mazda dealership has told me about this problem, I suspect there is at least 1000 vehicles off the road right now. Maybe we can raise this issue together and hold Mazda accountable for the inability to provide a reliable motor for their customers. I really don't want other people to have to go through what I have been through.
Anyway, if anyone has any ideas about how this issue could be taken further as a group, I'd like to know.
Hi Ribbs,
Do you mind letting me know if your second gasket failure was within a warranty period as a result of the previous repair or out of warranty but being honoured in good faith?
I'm curious as we had our engine rebuilt in June of 2021 under warranty due to the engine recall and our motor blowing. Fast forward to now 2 yrs and 5 months later we have had yet another issue with this car and have a suspected cracked head gasket. Mazda won't commit to saying if they will or won't cover this repair as it is now outside of the two year warranty until we sink almost $1000 into pulling it apart and testing. Just trying to weigh up our options and seeing if anyone else has had the engine go yet again after being fixed due to the recall.
Any help you can offer would be appreciated.
Old Dec 24, 2023 | 05:14 AM
  #292
Musashi's Avatar
Rebekah, what is the actual fault or symptom with your CX-5?
If its the headgasket, there is no recall Issued by Mazda Japan or Mazda NZ or Mazda Australia for this. As much as it sucks,
​​​​​​There was an "SH Engine" recall on my Mazda CX-5 in 2021, this is on the Mazda NZ recall website. What that means is I do not know, but it was recalled.
Old Dec 24, 2023 | 07:01 AM
  #293
Recall was inspections and replacing a few small parts.
Old Dec 27, 2023 | 04:30 PM
  #294
dieseltradey's Avatar
This is my personal opinion of the Skyactive 2.2 Diesel engine. My experiance is Auto Machinist, Diesel Mechanic qualified. Worked on heavy and lighter diesel engines all my life. Overhauling variety of engines in business for myself. Was owner of 2016 CX5 Diesel 2.2 engine. Under warranty had recall for dipstick replacement. When picked up asked what was the issue, was not convinced when told dipstick was marked with an X above the full mark. This meant as soon as the oil level reached the X mark to have oil changed as soon as. Told the person are you saying this must be diesel fuel thats going into the oil ( approx just over a litre to reach that mark) Mazda would be THE ONLY ENGINE MANUFACTURE IN THE WORLD that says its ok to run diesel in the engine oil. By thinning that oil supply you will have problems with components that require a good supply of engine oil. That being Turbo, Crankshaft Big-end Bearings, Camshaft bearing problems. This engine is a Lemon, briefly diesel engines require a Compression Ratio mainly above 16:1 to ignite the fuel squitered in by injectors. Anything less and you will not efficiently ignite that fuel. Mazda runs 14:1 so they now have to come up with ways to ignite that fuel. They have introduced the heat of exhaust gases which have ignited in cylinder by closing off the exhaust valve sooner. This carbons up the intake manifold which contributes to engine failures. I have explained this to Mazda who cannot with what to do about these issues, except to say avoid aroun town running. I have traded it this CX5 for the petrol version.
ONGOING Repair service history
  1. February 2018 – 52333kms,strong smell of fuel
  2. September 2018 - 62081kms, FUEL SMELL abnormal fume smell. please check Carried out inspection, Carried out fuel injector value reset as required.”
  3. January 2020 –81461kms, “ENGINE RUNNING ROUGH. Customer advised vehicle had loss of power twiceand has overheated, found no coolant in reservoir.. Carried out head gasket test; all okay. Found coolant leak from the coolant junction box below the intake manifold. Removed and replaced the coolant bypass due to leak. Re-tested coolant system”’.
  4. March 2020 – 84202kms, “Was recently in to complete the engine recalls and now Master warning light has come on -Vacuum pump replacement -
  5. May 202085455kms, “ONGOING ISSUE WITH ENGINE: losing powervehicle losing power parts have been ordered Checked and found turbo charger assembly to have premature internal failure causing the vehicle to loose power. Removed engine, replaced turbocharger assembly and all relevant gaskets and seals. Re fitted engine,
  6. February 2021 97376kms, “ONGOING ISSUE WITH ENGINE: losing power inspected and found failure of exhaust pressure sensor.
10. January 2022 - 114,829kms the vehicle COMPLETELY SHUT DOWN with absolutely NO warning, NO LIMP MODE . Vehicle presented with the MIL and Master Warning Light illuminated. Carried out oil pressure test and found a low oil pressure condition. Found a combustion leak from number one injector.
Current
  1. 15 June 2023 (16 months later) 145622kms, the vehicle is EXPERIENCING THE SAME power loss issue AGAIN. The vehicle was towed to Mazda Newcastle, they have had the vehicle since this date.
“ENGINE FAULT. INSPECT POSSIBLE COOLING SYSTEM OVER PRESSURISIBNG - HAS HAD COMBUSTION LEAK REPAIR CARRIED OUT PREV AT COFFS MAZDA 2022 - QUOTED $350.00 DAG DEPENDANT ON FISDINGS,
Carried out general inspection and found coolant stains around engine bay.. Completed test for engine combustion gas present in cooling system (TeeKay test) and confirmed.Reported results through to Mazda Au technical assistance. Carried out the removal of engine accessories as required to carry out engine compression test and engine cylinder leakage test. Compression test: 1) 217psi, 2) 290psi, 3)159 psi, 4)203psi.
Mazda will NOT agree to pay for the further investigations.
Please help![/QUOTE]
Old Jan 1, 2024 | 11:51 PM
  #295
shandon's Avatar
Hi my daughters car has blown the head gasket on the 2.2 motor (CX5) 2016. They are strapped financially. Would it be possible to contact you as they have been quoted 8k by Mazda in Chch
Old Jan 3, 2024 | 10:14 PM
  #296
Sorry to hear your daughter is having trouble with her 2.2 diesel. With your quote sounds like they must be doing more than the remove cylinder head, surface grind head etc and refit. As i have stated this engine with 14 to 1 comp. ratio means as stated by Mazda they could build the engine light. Aluminium Block and Head like a petrol. (Note; Diesel optimal Comp. ratio 18 to 1. Petrol optimal Comp. ratio 8to1 to 12to 1.) The use of Aluminium in diesel engines that operate under severe stress and temperature conditions is limited. Also note Compression reading for Petrol engine is 125 to 175 psi. 8 to 10 comp. ratio a Diesel is 275 to 400 psi with 15 to 20 comp. ratio. Twice as much as a petrol. That is the reason most Diesels have a cast iron cyl. block and head. In the specs on the 2.2 Skyactive diesel they say because of the 14 to 1 Comp. ratio they are able to save so much weight on the engine. The construction of the cyl. block is all Aluminium with free standing cylinder bores. A normal cylinder block petrol or Diesel lets say is a block of Cast Aluminium or Cast iron. A normal would have the cylinder bores at the block face connected to the outside edge of block. the only interuption being casting holes to allow coolant to suround cylinder bores flow up through these holes matchinh holes in the cylinder head. You have that full support from cylinder bore to outside etge. In the Mazda Diesel they do not have that upper support. In fact there is no connection to outside of block. What you lose there is the suppot/strength of bore and block which takes all the load when the fuel ignites at TDC (Top dead centre) The cylinder bore is cast in with the lower half of the bore in the block. But where the explosion occurs at TDC you do not have that support/strength. In my life time i have seen other engines manufactured this way and generally they have head gasket problems. Take a look on line at Mazda 2.2 cyl. block and the picture willshow what i'm trying to explain. Mazda have stopped the avaliability of this engine. Unfortunately owners suffer and Mazda is walking away with no liability. My CX5 Diesel had only 21000 klm. on it was brought new from local dealer, so they were obliged to take it as a trade on a new vehicle. I tried Turners but it is there policy do not trade Mazda Diesels. On my CX5 they said if forced i would be lucky to get $1000 they may get $3000 for it. Sorry for the drawn out reply but difficult to explain in layman terms. It may be worth a visit to your local engine reconditioners who may suggest a head surface grind then sell the car. They would have experianced this issue i'm sure.
Old Feb 7, 2024 | 07:56 PM
  #297
GAM's Avatar
GAM
Default Mazda CX5 2.2 Skyline Diesel - Blown Head gasket
I’ve had my CX5 now since January 18, I’ve generally had the car serviced by a Mazda dealer throughout those years.
End of 22, I started to have a few issues, the “Check Engine light” started to flicker on & off, would come on for one or two days then disappear for two/three weeks. Then a couple of times over Xmas 22/NY 23, the Master Warning light would flicker on as well, again, would stay on for a day or two then disappear.
January 23 I booked into a Service @ Mazda discussed the issue, they believed that the Vacuum pump may need to be replaced (Master Warning Light was not lit at that time) but did not know why the Check engine Light was flickering on.
January - July 23 - “Check Engine light” started to flicker on & off, would come on for one or two days then disappear for two/three/four weeks.
July 23 “Check Engine light” came on along with the Oil Warning Light, Oil Warning light disappeared again but Master Warning Light came on and stayed on, along with the Check Engine Light - Booked it in to Mazda for a Service & to investigate.
August 23 - Mazda, investigated and they advised that “Check Engine light” was likely down to whoever completed the Service before, over filled the oil and that was getting into the Diesel. They also confirmed that the Master Warning light diagnostics required the Vacuum pump to be replaced (which was replaced once the part had been ordered & in stock).
October 23 “Check Engine light” came on for 1 day then disappeared again.
December 23 “Check Engine light” came on for 1 day then disappeared again.
December 23 “Check Engine light” came on, then within approximately 30 seconds the Oil light came on, after another 30-45 seconds the car lost all power. As this was over the Xmas period so I got it towed to a local Mechanic who advised that it was likely a Head Gasket and that it may be not worth fixing. After Xmas/NY I booked the car into Mazda, they ran diagnostics and confirmed that it was a Head Gaskett but needed to complete a further investigation costing $1,095 + parts in accordance with Manual IF Po55F to confirm whether it did require a partial engine replacement (head gasket). The team then advised that I was looking at a possible $5-6,000 cost to repair.
Reading through some of the comments in the Forum, it seems this is a common problem and that the initial problem with the oil leaking/seals which the leads to issues with the Vacuum Pump and Head Gasket is well known to Mazda.
This has now left me pretty frustrated with Mazda NZ, my Mazda is well out of Warranty (2014) however we obviously pay a premium to go to Mazda and would expect them to pick up these issues and notify me & resolve them. At the Service back in January 23, when they thought that the Vacuum Pump may need to be replaced, is it being unreasonable for me to think that they should have picked up on this and let me know that there is a general issue with these Engines, which I could have possibly resolved then. Instead of waiting for the Dashboard to light up then blaming the previous Mazda Service Engineer and the engine to blow.
I doubt if I can get any recourse from Mazda but it's left me very frustrated. Repair costs aren't worth it so I can only get scrap money now, after paying out $3,000 this year on servicing, diagnostics and vacuum pump replacement then to have it blow up on me, with Mazda seemingly hiding the issue and leaving me angry and well out of Pocket.
If anyone has got any similar experiences with Mazda please let me know.
Thanks
Old Jun 22, 2024 | 05:25 PM
  #298
Robmorrisy's Avatar
Default 2015 CX5 Compression Loss
Hi there, I’m after some advice.
My 2015 CX5 Diesel, 118,000 kms, has recently had an engine failure. It is a Jap import and we are the first NZ owners, having owned the vehicle since 2020, 91,000 kms.
While driving it lost all power with no warning signs, and is now crank no start. Check engine light and battery lights are now on, but no codes are being read with an OBD2 scanner. We have never had an issue with the vehicle and nothing has ever been raised to us during servicing.
An independent mechanic has done an initial diagnosis of no/low compression, but stopped short of doing a full compression test as he advised it may not be worth it. Battery and starting system were both checked and confirmed as good, car would not start on Ether, so rules out the fuel system too. He advised that to get the car back on the road it would most likely need a partial engine rebuild and with the cost of parts and labour it would cost close to, if not more, than the value of the car. He suggested I do some research before deciding whether to progress as he knows there are some common faults with this engine.
1. Has anyone else experienced something similar, and if so what was the cause/issue?
2. From reading above, Mazda NZ does not look kindly on Grey Imports, has anyone had any luck getting support from the dealer who imported the vehicle? Or Mazda themselves?
Thanks
Old Jun 23, 2024 | 07:35 AM
  #299
There have been minor & major issues with this engine since 2012.
Do a quick search here on the forum and will see as such.
My advice is to count your losses and do some Internet research before you purchase your next vehicle.
Had you done so before buying your 2015 diesel you'd have seen the potential engine issues.
Good luck.
Old Aug 19, 2024 | 07:06 PM
  #300
rchris's Avatar
Smile CX5 Diesel
I have a NZ new CX5 D which I purchased new in June 2015. It’s now has 170,000ks which is a mixture of city driving and open highway driving of around 200k trips. I have always had the engine service completed on time or early with fully synthetic DPF compatible engine oil.
I have had the Mazda Recall for the injector seal washers and a couple of other minor recall items, rear hatch gas struts ect.
This is this the absolute best diesel car I have driven or owned, very quite sounds like a petrol engine, massive torque both low down and on the highway. My average fuel consumption sits between 6.7 -6.9. Goes to 10.8 when towing 22 ft caravan which is still great.
I have never had OIL level move either up or down between oil changes.
I have never had the radiator lever change in the expansion tank outside of the normal range.
I have never had any issues with my engine, or any engine lights. I do not use the stop start functionality - ever, maybe this has a detrimental effect on these engines. If you want to disable this functionality, easily fixe by adjusting micro switch in the bonnet catch, the start stop is disabled if the micro switch detects the bonnet is not shut completely.
my back brake pads wear faster than front brakes and the outside back brake pad wears twice as fast as the inside one, so at 30,000 k rotation is good. I have read that with electronic braking the computer programs light braking to the rear first then front brakes during heavy braking, as I am not a heavy breaker it may be why my rear brake pads wear faster than front brakes.
I’m sorry to hear that some owners are having a bad run with the CX5 diesel engine but it appears from the amount of these that were produced and sold these problems are in the minority group. Unfortunately all vehicles have a common weak point, I had a Jeep Wrangler 4.0 and these had a common tendency to break a piston skirt but again it was a “common minority”
Again I’m sorry if you have fallen in the minority group with this engine problem but the majority of the CX5 diesel owners are very happy with this vehicle. Every vehicle type has a forum group discussion regarding common problems which is a great source or information.
