Confused about towing capacity and requirements
Old Jan 26, 2023 | 06:32 PM
tempo's Avatar
Originally Posted by Geluk
Those numbers are completely different from the ones found in my manual, go figure, are they just winging it?: 2014_cx-5_manual_en_optimized.pdf
However there is one thing that makes sense to me here, the TTW definition:
TOTAL TRAILER WEIGHT: Sum of weights of the trailer and its load.
That's it! That's what I thought it should logically mean. Why does the NA version, at least for the 2014 model (EDIT: I just checked they're all the same up to 2023), have such a weird definition for the TTW?
The total trailer weight (TTW) is the sum of the weights of the trailer load (trailerweight plus cargo), trailer hitch, 2 passengers, and vehicle load (baggage, food, camp gear, etc.).
That sounds more like the GCWR definition no?
Old Jan 26, 2023 | 06:37 PM
tempo's Avatar
I agree with Callisto . IMHO after many years of seeing what towing does to light duty vehicle transmissions ,your Mazda CX was not designed or properly equipped to tow . The trans will be strained ,your brakes, will prematurely wear out, your differentials will be over stressed, your cooling system may suffer from over heating . A big trans cooler and temp gauge may help some ,but unless your going to tow very light loads on level ground ,your looking at accelerated trans wear and damage leading to premature trans failure and the need for expensive repair or replacement. If I were going to tow with a CX5, I would get a big trans cooler, and tow very light, take it real easy and change the trans fluid and filter more often . A proper full trans rebuild will cost in excess of $3000.00.
I'm sure you are right however I don't really care about possible dammage, I'll bite the bullet if it comes to that, I just want to safely make a road trip with a small light travel trailer. Saw some as low as 1300 lb that would fit our needs even though I'm sure with propane, drinking and grey water that number goes up quite a bit. Say + 500 lb. If I can just install aftermarket brakes and controller on the CX5 I will, and maybe a sway prevention system. But I can't even figure out what the freakin manual says about what my absolute safe max is. It is complete nonsense.
Old Jan 27, 2023 | 11:00 AM
I am pretty sure that you will drive sensibly with the trailer? That is reduce your speeds and even more so on adverse road and weather conditions. While MAZDA has that somewhat confusing towing schedule, I can tell you that the chassis was NEVER really designed or engineered for towing high weight values. The mid-section has not structurally reenforced so in turns you will be stressing the complete chassis. The suspension as it will work under MAZDA towing schedule but will also be taxed to its limits.
As I mentioned earlier if towing for a long periods with your MAZDA's life you should consider investing in some suspension, cooling and braking upgrades?
Old Jan 28, 2023 | 02:25 PM
tempo's Avatar
At this point I think I will just consider exchanging it for something with a V6 engine and better (and less confusing) towing capacity.
Old Jan 29, 2023 | 10:40 AM
Your Mazda is a good and sound vehicle, My posting is simple and can be that same thing I would post regarding towing on any platform forum.
There are some vehicles that more consideration beyond what the max limits and specification from the OEM label for safety and having a trouble free adventure.
Ford Explorer is a great vehicle but the towing recommendation on the Sport caused a few disasters with U-haul rentals to the point you can no longer rent trailers for them. Yet people during that time period still were seen towing full size trailers. I would suspect they used a little more common sense or were just lucky not to have disastrous problems?
When in unsure simply lower your total towing and passenger capacity. Same as flying you can do all the proper weight computation but if that hesitation passing in your mind pops up then reduce to total weight (not the fuel ) and fly safe!
Old Jan 29, 2023 | 03:22 PM
schmieg's Avatar
I was never sure what the problem was with the Explorer. I had a 97 with the V6 that I used to tow a horse trailer with a horse. Of course, the vehicle had a weight distributing hitch and a trailer brake controller, but I never had any problems with it. I did try to rent a small U-Haul trailer once and they would only rent me a truck, so I used the horse trailer to haul the several pieces of furniture 100 miles to Lexington.
I will grant that when I replaced the Explorer with a 2004 Tahoe, the towing experience was much better, but the Tahoe was a heavier vehicle with a nice V8.
Old Jan 30, 2023 | 09:19 AM
I was talking about Explorer Sport not full size. I had an 98 XL V6 and towed all my cars with no problems. Also complete upgraded suspension and E-brake and that included the transmission which we know got the nick name "exploder". .. The sport 2 door (runt 1/2 a real Explorer ) many would just call them Explorer, but they were far short of the full size 4 door. The Sports were the ones that gave the Ford Explorer the bad towing reputation hahaha! .
Old Jan 30, 2023 | 11:37 AM
schmieg's Avatar
That makes sense. The Sport wasn't long enough for towing, but U-Haul did not make a distinction. Regardless, the Tahoe was far superior and my daughter is still using that 2004 to tow the horse trailer.
Mazdaman714
Jun 29, 2022 09:43 AM
Sojourner55
Mar 27, 2022 09:01 PM
jdpowell
Nov 2, 2019 09:01 AM
FlyBoys
Aug 20, 2009 06:26 PM
thelionsof
Jun 6, 2007 10:53 AM
