Brake issues
Brake issues
Hi
On my CX5 when breaking I was getting steering wobble and vibration on the brake pedal which felt like a warped disc. I’ve had new disc's /pads /Calliper's and disc carriers fitted but the issue has come back.
Could it be another part with in the brake system? Does anyone have any ideas
Cheers
Cheers
Hi
Cheers
Cheers
This exact question was asked recently... somewhere else
In General I must point out for all readers that any problems should be identified before parts replaced. This will prevent replacing un-needed parts and also parts that may contribute to worsen a condition or add new ones to solve.
You need to look at steering components and the ABS and Traction system. Go to Factory Service Manual that will in detail described what and how to check the ABS and Tractions control system. As for suspension if you are not sure go to a Firestone or other that generally offer a free estimate inspecting for front end alignment which will usually indicate worn steering parts. You can look at the wear pattern of the tread if you routinely rotate your tires in the proper pattern. This may also lead to a dampener or 2 that are needing to be replaced?
