BPB/BOV & CAI for 2021 Signature?
Old Nov 4, 2023 | 02:14 PM
Never-Enough's Avatar
Default BPB/BOV & CAI for 2021 Signature?
Picked up a 2021 Signature. Looking for aftermarket BPV/BOV & CAI options that won't do any harm. Have a turbo? I want to hear it lol
Old Nov 5, 2023 | 08:52 AM
If you try to install a BOV on a newer Mazda you are either going to need to live with the Engine check light on all the time or get a ECU Calibration.
There are not true CAI for your Mazda but there are some kits that will replace the factory air intake filtering system. Keep in mind they will not give you any increase in power and may cause the IATs to be higher than normal.
I also like to hear the Tubocharge o my engines as well.
Contact them directly about application.
2017+ CX-5 Aftermarket Parts | CorkSport Mazda Performance
For ECU calabration:
VersaTuner
Old Nov 5, 2023 | 08:59 AM
VersaTuner
Then CAI only it is!
Old Nov 5, 2023 | 09:08 AM
Consider and keep in mind what I said. Not sure what the summer ambientes are there in PA but low engine speed driving around town will cause much higher IAT's. In a Turbo engine the ECU will start to retard timing, and change fueling to cool the engine. Your engines power levels will go down. You will likely not be able to run anything except 91+ octane fuel to keep the engine safe. The knock sensor has limits as do the ECU to react and adjust to higher IATs.
These are things most don't consider, know or adjust for when using a aftermarket CAI/noise maker (not a true cold air intake).
The factory intake filer actually does a better job than currently any so-called CAI that is marketed for most all newer Skyactiv gasoline engine from Mazda.
I might add on the subject of CAI. Many think that these air intake filters & kits will lower their IATs. The mistake is the best they would be able to do is equal the ambient. And even some semi workable IATs cannot lower the IATs if the Throttle plate is less then 35% open to allow the flow of the air intake charge to "FLOW" through the engine. Air intake charge will heat in the intake manifold with low vehicle speeds and RPM.
Old Nov 5, 2023 | 09:12 AM
Thanks, I'm aware. I've owned a lot of cars.
Old Nov 5, 2023 | 09:16 AM
And I build True CAI as well Performance Turbochargers (big wheels and fully ported) for other platforms. Sorry nothing for any MAZDA \
The market is flooded with too many aftermarket products, mostly junk to even try to introduce anything that actually works.
Kamal El
Jun 30, 2017 08:18 PM
vlstellato
Aug 6, 2009 03:29 PM
Captain GJ
Sep 28, 2007 08:26 AM
Nebolskeetskeet
Aug 3, 2007 02:03 PM
bill1986
May 1, 2006 11:24 AM
