2017 Mazda CX-5 Airbag Light
Old Aug 3, 2023 | 08:15 AM
jculleny's Avatar
Default 2017 Mazda CX-5 Airbag Light
I am looking for some help!
The airbag light on my dashboard has been flashing for the better part of a year. I have mistakenly spilled water on my passenger seat multiple times, which I believe has led to the issue. I read the code and it is a DTCB0011, which doesn’t tell you much. We did find that one of the resistance readings (see images) is high which I believe to be the problem.
We took apart the center console and got to the airbag module underneath the cupholders. We reseated all of the connections but the light is still flashing. I think something on the passenger seat is causing the issue. Any recommendations or technical advice is much appreciated.
Old Aug 3, 2023 | 06:10 PM
First thing to do is check ALL the connections which you may or may not have done, you'll need a service manual to verify all of them.
I say this as I have no idea exactly how many connections are in this "loop", but I do know there are some in the seat itself.
It is no easy feat removing and reinstalling the seat.
Here's they actual definition of the code:
If the Restraints Control Module (RCM) detects a short between the passenger air bag stage 2 circuits and the circuits of another SRS component, it sets this Diagnostic Trouble Code (DTC) and the DTC of the corresponding SRS component. The Restraints Control Module (RCM) monitors all deployable device and sensor circuits for a signal cross coupled (short) between circuits. If the RCM detects a short between the circuits of one device and another device, it will store a DTC for each of the signal cross coupled faults in memory. The RCM sends a message to the Instrument Panel Cluster (IPC) to illuminate the air bag warning indicator. When a normal loop fault is present (one loop is either shorted to battery/ground, open circuit or low resistance), then signal cross coupled diagnostics will not be active. Once the normal loop fault is repaired, then the signal cross coupled diagnostics will resume.
Old Aug 12, 2023 | 06:21 AM
A quick google of DTCB0011 shows it being the passengers airbag in the dashboard, not the seat. I could be wrong.
securitysimon
Aug 29, 2022 07:53 AM
Dia3103
Jul 17, 2021 10:07 PM
Hannahlou0618
Mar 6, 2020 08:34 AM
Sean Minear
Sep 23, 2019 03:18 AM
ranshe
Feb 8, 2015 06:09 AM
