Coolant
Old Sep 16, 2020 | 12:07 PM
geekgwk's Avatar
Default Coolant
I have a container of Prestone 50/50 that I had for top ups on my previous vehicle. The Mazda specs are for FL-22. Is it wise to use the Prestone for top ups on the CX-30?
Old Sep 16, 2020 | 01:24 PM
You did post which Prestone you are using. 50/50 is not the type only the mix.
However when you retrieve that you can actually go on line to Prestone and answer your own question . Their website shows the compatibility information.
Their are coolant supply companies that specifically indicate FL-22 compatible.
IMHO if you are in Arizona your could use distilled water for topping off a reservoir. But if you are constantly having to do that you may consider getting your cooling system professional checked.
Old Sep 17, 2020 | 08:23 AM
Do not use anything except for FL22 coolant. ( Both Ford & Mazda sell FL22 long-life coolant )
Do not dilute your factory coolant with any type of water.
rtaylor
Mar 22, 2021 08:44 AM
rlb
Jun 24, 2014 02:16 PM
bozanbo87
Nov 5, 2009 05:43 PM
Kevin056
Aug 4, 2007 12:56 AM
mazda guy
Nov 12, 2005 03:33 AM
