Truck Died
Old 03-05-2008, 10:14 AM
mxer201's Avatar
Default Truck Died
While driving home the motor in my B2600i decided to die on me. No warnings or anything. Right after it died I believe all the idiot lights came on including the HOLD light. I thought it was odd the HOLD light coming on. Once stopped I tried to start it and it seemed like it would try to run for a second but no. Haven't been able to work on it yet but the first thing I'm going to check are fuel delivery and ignition spark. Computer was repaired by AVproecm back in 2004 so hopefully it is ok. Any suggestions before I get started on it?
Old 03-05-2008, 09:29 PM
mxer201's Avatar
Default RE: Truck Died
Got er done!! Problem was the ignition coil. No spark at all. I replaced the original coil with this one from O'Reily back in 2006. Good thing about the O'Reily part is that it has a limited lifetime warranty. I'm glad I saved the old coil. Once the old coil was installed the motor started instantly!
Old 04-11-2008, 03:58 PM
You can run a diagnostic test as a preliminary thing to do. If those readings come up with some stuff it would be a good thing to start where it says. Good job fixing!
TANK1
05-22-2011 03:47 PM
bloodsweatgears
02-04-2009 04:14 PM
willy3486
11-28-2008 08:11 AM
defaced
12-19-2006 01:07 PM
jjrrbak
06-16-2005 03:34 AM
Quick Reply: Truck Died
