gas milage
Old Jun 3, 2009 | 11:09 AM
louzda's Avatar
Default gas milage
I am getting about 23 miles per gallon. What is everyone else getting I have a 89 b2200 and that is not very good, for a small pickup. What can I do to this to get better gas milage?
Old Jun 4, 2009 | 03:15 PM
mazda323_87's Avatar
full tune up,i have a 89 as well.
what i did was changed:
ignitor (in distributor)
spark plugs (ngk)
new distributor cap and rotor
new spark plug wires (ngk)
new coil (oem)
thats for the ignition.
for fuel...
new fuel filter
dropped the gas tank and pressure washed (these trucks have a tendency to rust inside the tanks.)
seafoam (3 parts to a bottle in the gas,3 parts in the oil,3 parts in the brake booster vacuum line)if you need further assistance just ask,causes smoke from the exhaust.
full tank of fresh gas(i used the shell v-power)
i installed a weber kit,old carb was terrible and was part of the low gas mileage.(also comes with new air filter).
fresh oil change and filter after seafoamed.
new belts
everything else.....
fresh coolant
new thermostat
new radiator cap.
highly recommend a radiator/engine flush.
depending if your trucks automatic a new trans filter and atf fluid.
if its never ha one in a while youd probably feel a world of difference
this is very costly but if your intent is you want a reliable worry free truck this is a good starting point and like me dont like suprises while driving.
Old Jun 7, 2009 | 08:22 AM
louzda's Avatar
After all that, what kind of milage are you getting?
irishwake
Aug 8, 2007 11:20 AM
esloyer
Apr 10, 2007 09:39 PM
Ransack
Sep 27, 2006 12:41 AM
nastynate
May 6, 2006 01:11 AM
goldy
Jan 6, 2006 11:53 AM
