carb to fuel injection
Old May 31, 2009 | 08:25 AM
louzda's Avatar
Default carb to fuel injection
Has anyone ever switch say an 89 b2200 from carb to fuel injection? If so was it complicated? what had to be done? and if so could you walk me thru step by step. Or should I go with a weber carb?
Thanks
Old Jun 1, 2009 | 08:04 PM
louzda's Avatar
I have been trying to get this truck to stop choking on. I found a wire off the back of this part on the choke, which I think keeps the choke fully opened. I can't find any place to connect it to. Does anyone know where and what it connects to?
Old Jun 1, 2009 | 09:44 PM
mazdab2600's Avatar
going to efi you'll need more than the engine.
fuel tank and sending unit
wires to the rear of the cab or farther to the relay and ecm
ecm/computer.
the wire thats off-what colour is it?
if the choke is the electric model then yes there's a wire to heat it up.
will have to check my manual for wire colour.
heres a few diagrams to get you started.
Old Jun 7, 2009 | 08:27 AM
louzda's Avatar
Thanks for info, now the trucks carb is working fine, accept for the oil consumption. I took it to Florida 600 miles and came back and it only used 10 quarts of oil. That is alot. I suppose it needs a ring job.
mazdamissile
Oct 13, 2010 09:46 PM
Willie2124
Jun 17, 2009 11:29 PM
blasphemous
Feb 28, 2007 03:02 AM
STARBUCK
Sep 22, 2006 08:03 PM
Chilly
Sep 21, 2005 10:46 PM
