Clutch problem diagnosis?
My clutch has started to act up about two weeks ago. Randomly it wouldn't come back up after depressing it to shift. I would have to quickly stick some toes behind the pedal and pull it back for it to go back to the correct position. I have plenty of fluid in the hydraulic reservoir. It also recently started to engaged much closer to the floor instead of about half way out. Any ideas? Maybe the spring on the clutch pedal is going bad? I haven't crawled down there to look yet. Anybody else ever have this problem?
Clutch cylinders hints and tips (1) Bench-bleed the clutch master cylinder before installing.
(2) Loosen the line fitting at the slave cylinder a little before unbolting it from the transmission housing - and thread in and mostly tighten before bolting the slave cylinder back on during re-assembly
(3) Use a flare wrench for initial loosening and final tightening of the lines.
(4) Don't bend the line after it's loose.
(5) Thread in the line fitting several turns by hand to avoid cross-threading, maybe even get this started before tightening the clutch MC mounting bolts.
(6) Flush out ALL the old fluid when bleeding the system.
I am curious how much such job would run at a shop???? I would guess 1 hour flat rate labor and parts marked up to about $125, so maybe $225-$250. Am I close?
Haha! I had the master and slave cylinders replaced along with all the rubber tubing at a Mazda dealership I was near when my clutch stopped working. $900+ after parts and labor.
From Post #3 in this thread:
