clacking noise
Old Mar 17, 2021 | 11:07 AM
lokahir's Avatar
Default clacking noise
aloha, i have this clacking noise coming from my distributor near where the cap attaches to the body. it is a new cap, rotor wires etc. it is really loud and lasts way past motor reaching temp but eventually gets softer. i checked inside the cap and under rotor and points in case something fell in-the dist cap but there was nothing.
what i did notice and thats why im writing this, is the distributor shaft supposed to move in and out (up and down)? if you grab the end of the shaft you can move it up and down ( in and out ) about 3/32”. there is no side to side slop but it does move in and out. is this normal? any ideas to the noise?
1993 b2200 2.2l carbureted. everything is stock no mods.
more info . i was able to set idle, dwell and timing. besides the clacking sound it runs fine.
any help is greatly appreciated.
Old Mar 20, 2021 | 05:43 PM
AutoMechanic's Avatar
These don’t have points unless they have been added. The distributor should not move up and down. When you reinstalled the rotor did you put it back in the same position as the old one?
Old Mar 22, 2021 | 09:12 AM
lokahir's Avatar
thanks for the info but have already purchased new dist. i havent had to change a dist for a while and i couldnt remember whether they had play or not. so all good thanks
Black2600
Apr 15, 2025 05:49 PM
brsmith49
Nov 26, 2013 10:15 AM
MustStangSally
Aug 27, 2009 03:34 PM
Tallisen
Jan 16, 2007 08:04 PM
Alucard
Jun 9, 2006 02:10 PM
