94 b2300 will not start warm
Old Jan 15, 2007 | 11:06 AM
cdnmazda's Avatar
Default 94 b2300 will not start warm
I have a 94 b 2300 4 cyl it starts awesome cold once warm it will not start sometimes. It has lots of spark when this happens and the piston top has gas sitting on it. If I let it sit for a day or two it will start up again no problem.I went through and cleaned most of the connections on all the wiring harness then used a silicone grease to seal them up to stop any other corrosion from happening. I was using the haynes manual to check the codes for the ecm but when I put in the jumper wire then turned the key on and engine off the check engine light does not flash it is just on solid. Also the same when I try the key on engine running test aswell. According to the book the light should flash to let me know whats wrong. My ABS light is also constantly on. Any help will be appreciated.[/align][/align]Kelly[/align][/align]This is my first mazda ever but I have had a ford or two and I know they are very similiar.[/align]
maurasmiatia
May 14, 2011 08:41 AM
David01
Apr 13, 2008 09:28 AM
tom626lx
Apr 13, 2008 08:52 AM
jr31
Sep 24, 2007 02:47 PM
ptempy
Sep 24, 2006 03:26 PM
