626 WILL NOT RESTART IN WARM WEATHER
Old Sep 17, 2006 | 07:48 PM
ptempy's Avatar
Default 626 WILL NOT RESTART IN WARM WEATHER
CAN ANY ONE PLEASE HELP ME FIND THIS FAULT, 626 2LTR INJECTION 1994, IT WILL RUN OK, BUT WHEN I STOP THE THE CAR FOR A SHORT TIME, IT WILL NOT START, BUT WHEN LEFT FOR A FEW HOURS IT STARTS FIRST TIME, EACH TIME IT WILL NOT START IS IN WARM WEATHER,ITS BEEN FOR SERVICE AND CAME UP WITH CODE 17 POSSIBLE OXYGEN SENSOR/ECT SENSOR/MAF SENSOR, I HAVE ALSO TAKEN IT TO A FUEL INJECTION CENTRE, THEY JUST RESET BASE PARAMETERS FOR ENGINE MANAGEMENT AND CLEARED CODES FROM ECU,
THANKS FOR YOUR REPLY
IT CRANKS OVER AND FIRES AND TRIES TO START BUT WILL NOT START THAT WAS LAST TIME, THE TIME BEFORE IT JUST CRANKED OVER. SO I DON'T KNOW IF ITS FUEL RELATED OR NOT
Old Sep 17, 2006 | 11:25 PM
bkey71's Avatar
Default RE: 626 WILL NOT RESTART IN WARM WEATHER
Will need more info...
Does it not crank over? Does it crank but no fire?
If it cranks, do you know if it is a no fuel or no spark condition?
Old Sep 24, 2006 | 03:26 PM
tucsonas's Avatar
Never had this problem with a MAzda but once had a ford with this problem turned out to be a fuel pump, when it got hotter it would not start, die etc... fuel pump was pumping just the minimum, when it got hot the fuel changes (expands or contracts) and not enough fuel delevered to keep it going....
VanilliwithafewMilli
Feb 13, 2011 09:41 AM
CLWerleyTX
Oct 19, 2007 11:21 AM
theguy
Jan 28, 2007 04:27 AM
MAYz4
Aug 2, 2006 04:32 AM
