1990 626 back-up lights inop
Old Nov 21, 2005 | 07:42 PM
Finski's Avatar
Default 1990 626 back-up lights inop
I noticed that it was quite dark while backing up the other night, so I attempted to troubleshoot the backup lights.
With the stick-shift in reverse and the key turned on (without starting the engine) the white back-up lights do not light up. The bulbs look fine. I checked the bulb socket for power with a 12v tester; no power. I checked the fuse box under the dashboard and all fuses appear fine. I didn't see any marked "backup lights", per sae.
I have a hunch there's a micro switch that triggers the lights when the (stick) shift lever is placed in reverse. Does anyone know if this is the case? Also, any other ideas before I get too assertive with the tools?!
ps. The lights might not have worked for years.
Thanks, Finski
Old Nov 22, 2005 | 12:27 AM
bkey71's Avatar
Default RE: 1990 626 back-up lights inop
Here is a pic of where the back up light switch is. Look on the lower right side of the pic above NON TURBO.
[IMG]local://upfiles/1828/D9DDC26EDA424778A68AE913B2CB18F3.jpg[/IMG]
Old Nov 22, 2005 | 11:02 PM
babyhuey's Avatar
Probably right on the switch bkey. Power is supplied thru the meter fuse and would have many more problems than that if fuse was blown. As a good way to double check, disconnect the connector for this reverse switch and jumper across the harness side. Make sure it is the reverse switch though and not neutral switch. Wires in the harness side connector for the reverse switch are Black w/ Yellow stripe and Red w/ Green stripe. Back-up lights should come on with connector jumpered and key on.
iphoenix
Jul 12, 2012 01:09 AM
jaimie08mazda3
Jun 14, 2010 10:47 PM
hawker
May 7, 2009 01:44 AM
surrealistic
May 3, 2008 06:07 PM
dukesport
Mar 21, 2006 04:40 AM
