626 Missing at idle and on
Old Nov 18, 2005 | 03:44 PM
WhiteGTSofDeath's Avatar
Default 626 Missing at idle and on
When the car is at idle it will miss and then the idle will start to wander, sometimes almost to the point of stalling. I am trying to help a friend out and normally don't mess with mazda's or 4 cylinder cars. Why would it be missing?
The engine threw a code a few weeks ago and it said "massive egr vacume leak" i tried finding a leak in the egr system, but i couldn't find one. The plugs and wires have been replaced.
Old Nov 18, 2005 | 04:24 PM
babyhuey's Avatar
Default RE: 626 Missing at idle and on
What year 626 and what was the code #? Do not remember ever seeing a massive EGR leak code.
Old Nov 18, 2005 | 05:00 PM
it is an 03 and no i do not remember the code number offhand
Old Nov 18, 2005 | 09:20 PM
babyhuey's Avatar
Maybe the EGR valve is sticking open a little. Is this a US car? Last year of 626 was in 2002 in the US. How many miles are on the odometer?
Old Nov 22, 2005 | 02:11 PM
It is a US car, it probably is a 2002. It has 60k ish miles.
Old Nov 22, 2005 | 11:27 PM
babyhuey's Avatar
Several things you might give a look to that have run across in the past. Vacuum diaphram for fuel pressure regualtor ruptured that draws fuel directly in to the intake thru the vacuum supply hose. Hose connects to manifold at the #3 intake runner so #3 plug will be all black and fuel fouled. Intake manifold gasket blown out, usually at the bottom, outer corner of the #1 or #4 runner. Mass air flow sensor contaminated. When running rough, disconnect the sensor and see if condition improves considerably.
sirron9591
Aug 4, 2010 09:48 PM
kctxau
May 4, 2010 04:16 PM
trex66
Feb 21, 2008 06:10 AM
syrup1
Dec 17, 2006 01:32 AM
andy908hamblin
Oct 19, 2006 06:10 PM
