Timing Belt
Old Sep 20, 2006 | 08:29 PM
Blackout's Avatar
Default Timing Belt
If my timing belt on my 2000 protege 1.6l breaks will it do and other damage other than the blet busting I've herd that the mazda engines are built so that when the belt breaks the pistons and valves have enough clearance that they wont hit Is this correct?
Old Sep 20, 2006 | 09:56 PM
babyhuey's Avatar
Default RE: Timing Belt
That is correct Blackout. Your 2000 Protege engine is safe if the belts breaks. Just a tow bill. Virtually all Mazda engines that use a timing belt are called "clearance" engines so that the pistons will not hit the valves. Chain driven engines are usually always "non-clearance"
Old Oct 23, 2006 | 10:47 PM
Stu's Avatar
Stu
Hello Babyhuey: Does your statement apply to a 1996 Miller Cycle engine also??? I assume that it does..
Thank`s in advance
Stu
Old Nov 4, 2006 | 02:50 AM
mazzfan's Avatar
Yeah since you have a 'non-interference' engine, the valves and pistons do not occupy the same place so there will be no damage. So timing belt breakage is the least of your concerns.
kinni420
Jan 28, 2013 03:08 AM
mazda99
Aug 13, 2008 04:18 AM
homeflash
Apr 4, 2008 11:55 AM
tidyclio
Sep 19, 2004 01:36 PM
