RX7 No Heat
Old Oct 26, 2006 | 06:09 PM
trawets's Avatar
Default RX7 No Heat
I am the original owner of a 1988 RX7 that has a no heat problem. The temperature gage moves only slightly above cold after warm up and does not go any higher. There is no heat coming from the heater, it just blowes cold air. I have replaced the thermostat three times and still experience the same no heat problem. The hose from the engine to the heater is hot to the touch, but still no heat.
Old Oct 26, 2006 | 11:00 PM
bkey71's Avatar
Default RE: RX7 No Heat
The hose on the return side of the heater should be warm, but less warm. If it staying cold, that would signal a restriction in the system. It could possibly a restriction in the heater core.
Old Nov 4, 2006 | 01:36 AM
mazzfan's Avatar
I agree, water from engine should be slightly cooler going back to engine (if tempature is the same, chances are your heater core is plugged). Another thing to look at is a possible stuck heater valve.
Old Nov 21, 2006 | 06:32 PM
pickral 123's Avatar
make sure you have enough waterin the system other wise i agree with the other guys
MTMazda
Feb 3, 2007 01:45 AM
swoopes_30
Jun 11, 2006 10:17 PM
tsb2600
Nov 13, 2005 02:29 PM
bluemx693
Oct 19, 2005 09:48 PM
silverracer18
Oct 15, 2005 10:08 PM
