No Heat in '87 B2000 Pickup
Old Mar 6, 2006 | 04:54 PM
MTMazda's Avatar
Default No Heat in '87 B2000 Pickup
I just got a "free" 1987 B2000 pickup and discovered that the heater is not working. I checked the controls for the heater and they look like they are working correctly so I'm guessing that the problems is the heater core. Does this sound like the problem? If so, how hard is it to change the heater core? Any help would be greatly appreciated. PS. This looks like g great forum.
MT Mazda
Old Mar 6, 2006 | 08:49 PM
bkey71's Avatar
Default RE: No Heat in '87 B2000 Pickup
I would first check the engine temp to see if it is hot enough. If it has a gauge, does it run at about half way up? Also check to make sure the heater hoses are hooked up and not bypassing tie heater core. If the engine is running at a normal temp (about 190 deg) feel the heater hoses to see if they are both hot, if only one is hot I would suspect a clogged core.
Old Mar 16, 2006 | 01:36 AM
MTMazda's Avatar
Problem Resolved.... I back flushed the heater core at the car wash and presto... heater works.
Old Nov 28, 2006 | 09:16 AM
acflye's Avatar
how did you do that....my heat is not working.......90 b2600i
Old Nov 29, 2006 | 11:25 PM
mazdab2600's Avatar
what part of your heat is not working
engine not reaching operating temp ?(thermstat)
no heat inside from heater?(plugged heater core or control cable bent/binding)
Old Feb 3, 2007 | 01:45 AM
acflye's Avatar
well my temp hand stays at the bottom unless i get in bumper to bumper traffic and then it gets in the middle........but no heat......how did you backflush at the carwash?
Thelonius
Nov 27, 2008 05:21 PM
EDE1981
Jun 27, 2006 01:30 PM
bhc6
Mar 4, 2006 10:59 PM
poorboy_616
Feb 22, 2006 02:36 AM
Bill Hicks
Dec 20, 2005 12:38 AM
