Need to service my 1994 familia
Hi all. I need to service my Mazda famila as it has a miss fire. What do I set the plugs and points to and what should the timing be set to. The engine is running on both gas and petrol.
Thanks.
Swifty
Thanks.
Swifty
Do you mix the gas into the petrol and what's the mixing ratio? Or do you have separate tanks and you switch from gas to petrol?
As far as points and gaps go I can't help because I don't know what engine you have. You may be able to get a shop manual for your particular model.
need to service
Hi there many thanks for your reply. Yes I have two tanks one for Gas and one for Petrol so I can switch between the two BUT NOT AT THE SAME TIME. I have a UC 1400 engine. I can't find any information on it.
The other thing is I need to know what the rear axle ratio is and can I change it?
Swifty
Swifty
Swifty
Swifty
I have no information on a UC 1400 either.
No I don't run both Gas and prteol at the same time. I run it on LPG and some time petrol when I run low on LPG.
It seems I am the only one that has a UC 1400 CC engine. I can't get any help from anyone on this type. Just what do I do with it. I have now replaced the points and set the gat to 0.015 inch. The engind is running much better but I don't what the timming should be. So I have to guess and hope it's OK.
Auckland
10-29-2007 02:37 PM
