mazda bolt/screw/nut specs
I am in the middle of a large project and due to having a lot of time restrictions at times and just getting through everything I need to, I have unfortunately been unable to record the bolt size / pitch / length when I dismantled a whole CX7 and part MX5...
As I am now coming to putting everything where I need it to be I have all the bolts / nuts etc. but I cant find the exact locations of each one, this in some places wont be a massive issue as I can just replace with generic sized bolts and nuts if I use too many of one sort.
but with that said there are a few that I imagine I need to ensure are the right type / length - I can find the exact OEM part numbers but have not found a way to match these part numbers with exact specs - the workshop manual gives the torque specs but not length and thread pitch etc.
Is there a way to match part numbers to what type of bolts they are? im mostly concerned with length as the diameter and thread pitch will be easy to tell when I go to put the bolt in if its to go in or not.
boostmg
06-03-2019 02:17 PM
