Automatic Transmission won't upshift
Old Apr 15, 2009 | 08:05 PM
jjermzz's Avatar
Check this out this list of trouble spots
Trouble Spots
Consumer Guide's® Auto Editors have scoured repair bulletins and questioned mechanics to search for commonly occurring problems for a particular vehicle. In some cases we also give possible manufacturer-suggested solutions. In many instances these trouble spots are Technical Service Bulletins posted by the manufacturer, however, we have our own expert looking at additional vehicle problems.
Automatic transmission: The automatic transmission may not shift out of second or third gear due to a defective solenoid (the system stores the wrong trouble code often making diagnoses incorrect). The powertrain control module was being replaced under the standard warranty. (1999)
Battery: The battery may go dead due to excessive current drains from memories in components (like the radio memory or engine control computer). (1999)
Check-engine light: Drivability problems accompanied by check-engine light often due to EGR exhaust passages clogged. (1999-2001)
Cruise control: If the brake light switch goes out of adjustment, the cruise control may quit working. (1999-2000)
Doors: The power door locks may malfunction if contacts get wet or corrode. Countermeasure switches with rubber seals are available and were being installed under the normal warranty. (1999)
Doors: The doors may unintentionally lock upon exit. Redesigned switches are available. (1999)
Doors: The door weather strip comes off on some early production cars and must be glued in place. (1999)
Exhaust system: A booming noise from the exhaust system is corrected by installing a stiffener over the front muffler and a damper weight near the rear muffler. (1999-2000)
Keys: The key may be hard to insert or turn in the door lock because the flap breaks off and falls into the lock cylinder. (1999)
Rough idle: Drivability problems accompanied by check-engine light often due to EGR exhaust passages getting clogged. (1999-2001)
http://consumerguideauto.howstuffwor...-protege-2.htm
CX-5-2013
Jun 5, 2013 04:20 PM
JCG
Jul 26, 2007 01:29 PM
debbiev123
Mar 2, 2006 02:25 PM
jhenry
Jun 15, 2005 10:20 PM
enigma
Jun 7, 2005 06:59 PM
