2000 Protege ABS Error codes: 22 & 29?
Old Sep 6, 2013 | 05:16 PM
VABeach's Avatar
Default 2000 Protege ABS Error codes: 22 & 29?
Need help
2000 Protege (rear drums)
Ideas?
Old Sep 6, 2013 | 08:26 PM
go-part's Avatar
Former Sponsor
Get OBD1 Vehicle Diagnostic Codes
Old Sep 6, 2013 | 09:31 PM
VABeach's Avatar
Default Unable to find ABS Control Module
Thank you Go-Part!
Says 29 = Hydraulic Unit Right Front - Left Rear Brakeline
Says 22 = Circuit for the Hydralic unit / circuit for right front solenoid
Was told by a mechanic to replace ABS Control Module but having trouble finding one. Unfortunately not offered on the Go-Part site either.
Anyone know where I can get a part such as this for a 2000 Protege?
Old Sep 6, 2013 | 10:29 PM
VABeach's Avatar
Default ABS Control Module
Found an ABS Control Module for my vehicle at:
Genuine Mazda Parts at Wholesale - OEM Mazda Replacement Parts
Just ordered it.
Old Sep 7, 2013 | 10:45 AM
tanprotege's Avatar
A Year 2000 Protege or any car has OBD-I ????????
Old Sep 7, 2013 | 01:58 PM
VABeach's Avatar
Default Obd-i?
Hey tanprotege,
Does that mean that the descriptions I looked up for codes 22 & 29 do not represent correctly my ABS error codes of 22 & 29? If so, any idea where I can find an explanation of these codes?
I'm hoping the ABS Control Module I have ordered will correct it, regardless. I went with the ABS Control Module because a brake shop did a $75 diagnostic that concluded with this recommendation. They gave the car back to me saying Mazda no longer makes the part.
Old Sep 7, 2013 | 07:15 PM
tanprotege's Avatar
No, this only means that I am surprised . AFAIK 2-digit codes are OBD-I and you read them from the blinking CEL light. OBD-I was replaced by OBD-II in the early 90s. But it is possible that there are a few systems using the old codes.
I don't know and I would like to know.
Old Sep 15, 2013 | 04:14 PM
VABeach's Avatar
Problem solved.
Part above wrong but they confirmed an ABS Module (with pump attached) from a Protege with production date Sept-07-2000 to 2003, would work on my 2000.
Installed unit from a 2002 (bought on eBay). ABS light out & more importantly in dash Brake Light out. Just dropped for State re-inspection.
YEAH!!!
Old Sep 15, 2013 | 11:12 PM
tanprotege's Avatar
Good Job, VABeach! Thanks for the feed back!
simmonsp5
Sep 21, 2023 04:49 PM
N628PW
Nov 29, 2013 05:55 PM
Unicornasaurus
Jan 1, 2013 08:04 PM
rolandtignor
Aug 22, 2009 07:52 AM
popawalker
Dec 3, 2008 02:34 PM
