Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Amp Power Wire......Help!
Old Sep 6, 2013 | 12:44 AM
RunDougRun's Avatar
Default Amp Power Wire......Help!
Okay Forum:
I've searched high and low.....
Multiple sights....I have posted on this forum under the Mazda 5 board.......
"Where can I run my Power Cable through the Firewall"
I cant find anywhere....People say remove the glovebox......
Where are their instructions????
It's not like I haven't researched myself for about a week now......
Tips? Pictures?
Thanks!
Old Sep 6, 2013 | 07:55 AM
I have instructions for a Mazda 6 glove box removal, i'm sure they are pretty close.
If not check your owner's manual.
Click on: https://www.mazdaforum.com/forum/maz...zda-6-a-28561/
Don't forget to run an extra ground from the battery to vehicle body as well!
Old Sep 6, 2013 | 07:35 PM
RunDougRun's Avatar
There is no instructions for the Mazda 5 in my manual.....
People keep talking about behind the pedals.......
I don't see it.....
Am I crazy or is this power cord the hardest part of this whole install?
Old Sep 6, 2013 | 09:21 PM
Can you peel the carpet/insulation back from behind the pedal from the inside, and from the outside remove the battery? Removing the battery should give you a better view. Then you can drill a hole and put a grommet around the wire going thru (or silicone would suffice).
Old Sep 7, 2013 | 12:34 AM
RunDougRun's Avatar
I don't own a drill lol.....
Sad I know
any other suggestions.......
I did see a huge bundle of wires on the passenger side of the hood with a silcone-grommet
Can I poke through that?
Im out of ideas lol
Old Sep 9, 2013 | 08:10 PM
jaimie08mazda3's Avatar
Hell my power wire went through the firewall under the glovebox. There is a plastic cover for wiring from the electronic's to the engine and it had a rubber guard. Took that off and it went in. Find out if there is one for your car.
imurphy
Sep 4, 2010 12:02 PM
pr0cess0r
Sep 19, 2008 06:38 AM
DJ Ray
Jul 28, 2007 12:47 PM
t0md0
Apr 6, 2007 04:16 AM
dericsh
Dec 19, 2006 06:45 PM
