2008 Mazda 3S Stalled!
Old 09-20-2010, 11:27 AM
MrSpike118's Avatar
Default 2008 Mazda 3S Stalled!
Hi all! I hope all is well. I have a quick question. A few times when my car has been cold and starting it for the first time that day it would kind of hesitate when I was backing up, but today it stalled. I was completely baffled. The last time I had a car stall was when I had a 1980's Chevy Celebrity that had a carburetor. No check engine lights came on, I was thinking of trying to clean the Mass Airflow Sensor. Does anyone else have any good ideas? Any insight would be most appreciated! Thank you!
-Brandon
Old 09-20-2010, 04:19 PM
Tracker's Avatar
I forget auto or manual, does it do it every time in reverse?
Old 09-20-2010, 08:27 PM
MrSpike118's Avatar
It is an auto and yes it is when it is in reverse... Would/could that make a difference?
Old 09-21-2010, 03:53 PM
Tracker's Avatar
I looked it up on my service manual:
NO.24 ENGINE STALLS WHEN SHIFTED TO D, M RANGES, OR IN R POSITION
B3E050319090W28
24
Engine stalls when shifted to D, M ranges, or in R position
DESCRIPTION
• Engine stalls when shifting from N or P position to D, M ranges or R position at idle.
POSSIBLE CAUSE
• The malfunction is on the engine control side (i.e. IAC system). Otherwise, the malfunction is in the input/turbine speed sensor (engine sometimes starts) or the TCC circuit (engine always stalls).
Old 09-21-2010, 09:20 PM
MrSpike118's Avatar
So is this something I bring to the dealership like a tsb? Or just live with it? Thanks man...
Old 09-22-2010, 02:17 PM
Tracker's Avatar
its only something a dealership is going to have to look at, maybe ask an local auto trans shop about it
Old 09-22-2010, 03:07 PM
MrSpike118's Avatar
That sucks...i wonder if it would be covered under the 5yr/60k warranty? If not I will put up with it. Not paying for that. It has only stalled once. Bucked a few other times.
Jessab
01-01-2016 06:19 PM
Daisho
10-17-2014 10:16 AM
Captain Mazda
02-07-2010 12:11 AM
mazdamx6mm
08-17-2009 03:59 PM
Tallisen
05-03-2008 06:51 PM
Quick Reply: 2008 Mazda 3S Stalled!
