2002 Tribute Stalls when we put gas in it
Old 05-04-2014, 11:00 AM
MurrayandKim Daniel's Avatar
Default 2002 Tribute Stalls when we put gas in it
First we have replaced the catalytic converter when it wouldn't accelerate. Then we replaced the coil pack when it would stall out. The whole time when you put gas in it, it stalls out and idles very roughly. If you leave it on pumping, it stalls. When you turn it off to pump, you crank it and have to floor it a few miles and it straightens out. Any ideas?
Old 05-12-2014, 10:31 PM
CyberDaeng's Avatar
I have the same issue just a few days ago, and i have check almost everything and everything seems normal and i found out at last that the battery cable is not tight firmly enough. When I tight the screw in my battery cable everything works normal again.
Old 05-13-2014, 08:05 AM
tanprotege's Avatar
You let the engine run while you pump gas????!!!!!!
Emosh Gatron
09-02-2014 04:51 PM
linuxguy0481
04-14-2012 05:25 PM
jettamandan
08-19-2008 09:54 AM
freddy
11-21-2007 02:27 PM
pegman456
10-17-2005 07:20 PM
Quick Reply: 2002 Tribute Stalls when we put gas in it
