stalls out when the gas is hit.
Old Oct 16, 2005 | 01:10 PM
pegman456's Avatar
Default stalls out when the gas is hit.
I have a 1997 mazda 626 and when i put it in gear and hit the clutch and finally press the gas it wants to stall an most of the time it does stall out.All i want to know is what is the problem and how much it costs to fix.any help would be nice thanks.
Old Oct 16, 2005 | 11:00 PM
bkey71's Avatar
Default RE: stalls out when the gas is hit.
Please see this post>>>WILL ONLY IDLE. You sound as if you are plagued by the same problem I had. The Mass Air Flow sensor. Read the entire post about cleaning, this should help!
Old Oct 17, 2005 | 07:20 PM
babyhuey's Avatar
Good post to read thru. Does the engine try to stall out as well if reving it in neutral? Also does the vehicle roll easily in neutral with parking brake off. If not then maybe you could have the brakes locked up.
MurrayandKim Daniel
May 13, 2014 08:05 AM
dp4646
Sep 23, 2011 05:52 PM
kenyasing
Jul 29, 2007 10:03 AM
jakejohn
May 14, 2006 11:20 PM
Umar76
Mar 4, 2006 11:37 PM
