2000 Protege DTC p0118 p0171
Old 04-04-2007, 10:56 PM
johnnylavah's Avatar
Default 2000 Protege DTC p0118 p0171
2000 Mazda Protege
receiving error codes p0118 p0171. i have replaced the temp sensor, tightend the loose intake tube and still receive the codes.
any ideas?
Old 04-30-2007, 02:00 PM
Default RE: 2000 Protege DTC p0118 p0171
i replaced the intake gasket, the mass air flow intake and the o2 sensor and the car is still jerking while driving.....any ideas?
Old 05-01-2007, 04:04 AM
wsoape281's Avatar
ignition system maybe
Old 06-18-2007, 06:53 PM
i finally got rid of the p0171 code, but i still am receiving p0118 after replacing the coolant temp. sensor...any ideas?
Old 06-18-2007, 10:52 PM
MazdaES's Avatar
Did you check the standard tune up stuff, plugs, wires, cap and rotor. Also, when was the last time you replaced the fuel filter. These are things that might not show up as codes, but can cause other codes and symptoms to rear their ugly heads...
Old 06-18-2007, 11:19 PM
ORIGINAL: MazdaES
i replaced all of that....thinking it might have to do with the wiring harness or ecm
Old 06-22-2007, 06:59 PM
babyhuey's Avatar
How does the temp gauge read? Since you have only one temp sensor, The wire splits and one goes to the instrument cluster and other to the ECM. If gauge operation is normal would be looking at computer or computer connection problem.
1xwolf
03-19-2015 06:31 PM
sanders1977
04-09-2008 11:11 AM
steven237
10-15-2007 06:08 PM
jalinker
07-06-2007 08:03 PM
millie188
05-07-2007 11:45 PM
Quick Reply: 2000 Protege DTC p0118 p0171
