Mazda MX-6 cuts out after about a minute...please help
Old 08-22-2007, 07:53 PM
sandeshraj83's Avatar
Default Mazda MX-6 cuts out after about a minute...please help
I bought a 1995 mazda mx-6 in January, $2500, 100,000 miles and its been going fine up until now. I start the engine, and it immediately starts stuttering / choking, and after about a minute it will just cut out completely. Happens each time i start the engine. I can just about drive it before it cuts out and as long the gas is down, its fine, but when i come to a stop, it will begin to stutter again and most of the time will cut out. There is also a lot of black smoke coming out of the exhaust.
Does anyone know what the problem might be or what i should check out / replace before taking to a mechanic? The previous owner said the transmission might need replacing and the O/D light used to keep flashing on the dashboard. The only thing i've done to the car is change the oil.
Thanks
Old 08-22-2007, 08:27 PM
sstlaure's Avatar
Default RE: Mazda MX-6 cuts out after about a minute...please help
Black smoke indicates excessive fuel, blue smoke would be oil.
I'd check your fuel pressure and your injectors.
If I understand correctly, at idle it wants to die, once you're up to speed and on the gas you're OK?
Old 03-31-2009, 01:55 PM
colin.phillips's Avatar
problem you have with cutting out is consistent of overworked suction control valve due contamination or excessive filtration or plainly wear and tear . contact 01422 387800 for further assistence
wooberry
12-27-2013 04:48 PM
KiloWattson
01-17-2010 02:13 PM
theguy
01-28-2007 04:27 AM
coaky
09-13-2005 05:35 AM
Quick Reply: Mazda MX-6 cuts out after about a minute...please help
