1999 Mazda Millenia 2.3L SC Timing marks
I wanted to know if the timing marks on the crank pulley or the keyway mark on the crank pulley line up with the crank sprocket timing mark.. I wanted to know this so that i wouldn't have to go thru taking the pulley off to see the marking on the sprocket..Also does the crank pulley just bolt on and off off or will I need a puller for it...
Thanks
James
Thanks
James
if you go to mazdaworld.org, you will have to register. there is a tech section with pics and diagrams on exactly what you want. the crank pulley has one main bolt, then i think 8 smaller bolts. i have never needed a puller, but they can be cranky to get off
primemover
02-14-2012 04:00 PM
Ferret626
10-16-2010 04:36 PM
