Transmission (auto) stops shifting; dash lights go out
Old Jun 6, 2021 | 10:08 AM
maxnpj's Avatar
Default Transmission (auto) stops shifting; dash lights go out
This seems like an odd problem...at least to me.
2008 Mazda 6; I4; 2.3; 5 spd OD
Put the car in drive and off you go; sometime later the gear indicator on the dash will go out (you can no longer see what gear you are in or even if you're in D, N, R, etc; all other dash indicators are normal), and the transmission will either fail to shift up or down, or it will shift down. A slight wiggle on the gear **** sometimes corrects the problem, or I can move the shift lever over to the manual position and back and that fixes the problem.
I checked the transmission fluid and it seems to be the right color and level (I don't think fluid level has anything to do with dash indicators, but it was easy to check). I then thought it may be a gear shift selector "module" problem or is it maybe a cable leading to the gear shift selector that needs to be tightened?
Thank you for any advice.
Old Aug 16, 2024 | 09:56 PM
Drew30679's Avatar
Default Info
Hey man just wondering if you ever figured out what was causing this because I’m having the same issue right now
knyne313
Mar 24, 2024 10:57 AM
rlnull3
Jun 26, 2017 12:40 PM
El-Ghali
Jul 20, 2014 10:54 AM
VB
Oct 18, 2010 08:48 PM
msp5speed
Feb 20, 2006 04:43 PM
