Shifting and gauge problems
Old May 30, 2016 | 11:26 AM
Mazflee's Avatar
Cool Shifting and gauge problems
Hi all,
I'm new here and looking for some help.
I have an issue with my granddaughters 96 Mazda 626. 2.0L auto trans Last year I had the trans rebuilt by a professional trans rebuilder. Did it on the side as a favor. Recently the car doesn't want to shift correctly , the o/d off light flashes , the tach speedometer and fuel gauges stop working . If you turn the car off and restart it doesn't shift at all until o/d off starts flashing again. Three obd codes come up po 340 camshaft position sensor po500 vehicle speed sensor and po 443 purge valve. Most mornings the car runs . On the way home right from the start it doesn't want to shift until light flashes and then shifts hard . I don't think it's the trans again , I'm thinking a ground wire , found one broken and fixed it but no luck . Any ideas out there?
Old May 31, 2016 | 03:00 AM
My money would be on a faulty Speed sensor.
Old May 31, 2016 | 03:17 AM
Mazflee's Avatar
Thank you , I did a test on the vss that I saw on the Internet where you turn key on (with out starting), press o/d switch to turn on light. Then start car . According to the video if sensor was bad the car wouldn't engage into gear. The car in video did not, but mine did. However since last post I found another loose ground strap . Tightened it. So far , so good. But not 100% convinced yet. So just I case any other suggestions are very welcome.
Old Jun 4, 2016 | 05:34 AM
Mazflee's Avatar
Just a follow up . The car is running fine since I fixed the loose ground strap. Only problem now is the open door light is on all the time . Must be a bad switch .
RYOKOLOCO™
Dec 16, 2009 03:23 AM
oilersrule
Apr 9, 2007 11:49 AM
the_gray_mazda6
Nov 24, 2005 01:56 AM
andrewk
Sep 29, 2005 10:35 PM
paulie52
Sep 23, 2005 10:17 PM
