Mazda 2 - iStop Warning Alarm.
Hi All.... just new here so please be patient. I am in Australia. I own a 2019, Automatic, Petrol, Mazda 2 Hatchback. I do not use, nor want to use the iStop function.
My issue is as follows. The iStop amber warning light is on (Flashing). I know that the issue is a lower battery voltage than the alarm threshold level.
I can put the battery on charge overnight and the flashing alarm will disappear for a day or so.
I also am aware of the iStop on/off switch. This only controls the iStop function from cutting in. It does not prevent the iStop alarm from appearing on the instrument panel.
When I had the car in for its service at the local Mazda dealer, I asked them if they could get into the software and remove the alarm for me, as I neither use nor want the iStop function.
I was told that it could not be done.
Does anyone have some real insight as to whether it can be removed or not? After all it is only software / code.
Cheers and Thanks.
Cheers and Thanks.
Have you had the battery load tested?
The warning light only comes on when the batteries SOC, State of Charge falls bellow a certain threshold. If you are recharging the battery and light comes on soon after, either you have a significant current draw or the battery is dying.
I posted the cure for this some time back. Here it is:
If anybody is like me, I hate the i-stop function especially maneuvering into a tight car space, (touch the brake and buggar...stopped again) I know you can de-activate every trip but at my age I'm having trouble remembering my false teeth when I go out. Anyway, if you want to get rid of the bloody thing:
Open bonnet and remove two plastic push on clips on the cover over the bonnet lock.
Use a small screwdriver to unclip the two clips in next cover.
Then you will see a plastic switch with a philips head screw fastening it.
That has a notch in the underside which locates it.
Loosen it enough to turn the switch away from the metal contact and then tighten it up.
Done.....No lights no alarms no i-stop
Some are a little late to the party…lol.
members should read the last response date before just randomly posting? October 2023
Great answer but
the very first thing you do is always check the health of the battery by having it properly load tested.
ASE
Great answer but
ASE
[QUOTE=Callisto;235966]Some are a little late to the party…lol.
Sorry sport, it's been a while but I still see some queries about the infernal i-stop. Just trying to help
[QUOTE=harryu06;235981]
Its no problem but you should still read what I recommended about the battery?
Gazz
Jun 18, 2024 03:25 PM
