is there a way
Old Apr 3, 2008 | 10:22 AM
streetdemon70's Avatar
Default is there a way
is there a way to have the foglights that are in the headlight housings on a 05 mazda 6 come on with out having to turn on the headlights? and is there a special trick to getting the headlight housing out of the car? i took off all the bolts i could the other day and still couldnt get the housing out.
Old Apr 4, 2008 | 07:57 AM
Mazmart Trini's Avatar
Default RE: is there a way
I think that the bumper has to be removed first to gain access to the lower headlight bolts.
Old May 29, 2008 | 11:04 AM
MaggiesGirl's Avatar
Take off your grill (it just pops in and out but be careful because it will break) and take off your front bumper cover. It will be less of a hastle and you will be able to visualize all of the bolts for your headlight housing. There are 2 on top and 2 on the bottom near where the grill attaches. You will want to take out the headlight housing because you will not want to wrestle inside your engine compartment. It seems very time consuming but itreally will only take less than an hour.
I would like to be able to have my foglights on without turning my headlights on, as well. Maybe it is something that can be changed in the steering column with the ignition switch?
Old Jan 9, 2009 | 02:45 AM
04Mazda3Sport's Avatar
The fogs on with the headlights off is called Independent Fogs more affectionately called (Indy Fogs). Not sure if the process is the same as the 3, more than likely not, but search mazda3forums.com for the how-to's. It shows how to do it on the 3, and if you ask, it might just work for the 6 as well.
wishiwassailing
Nov 7, 2006 03:28 PM
ESPRO
Apr 7, 2006 12:01 AM
poorboy_616
Mar 2, 2006 03:51 AM
babyhuey
Dec 3, 2005 02:50 AM
psychomilly
Nov 19, 2004 08:01 PM
