Speedometer plastic cover
Old Jun 28, 2020 | 02:22 PM
Ar63's Avatar
Default Speedometer plastic cover
Hello
Does anyone know if the plastic speedometer cover is removable? Mine has a crack on it and I'd like to replace if it's not too much hassle.
Mine is a UK RHD, 2015 petrol estate. Would be helpful if anyone also knows the part number and/or has a trim removal guide for this area.
Thanks
Old Jun 29, 2020 | 07:42 AM
I'm quite sure you can remove the clear lense once you remove the instrument cluster form the car. Ring your local Mazda part department for a quote.
This link is for the US market. You may be able to select the best match model / specs for your vehicle. https://www.onlinemazdaparts.com/a/M...S/5442440.html
Old Jun 30, 2020 | 05:06 AM
Ar63's Avatar
Spoke to my local dealer, and yes, it's removable. The part is quite cheap as well. I found a removal guide which isn't quite for my car but will be good enough. For the moment I'm leaving everything alone, but should the crack get any bigger, I'll have to replace it.
Psygnosis99
May 3, 2018 05:36 AM
jakke7
Nov 25, 2014 04:31 AM
Iceman350
Nov 10, 2010 03:25 PM
d4tonyd
Mar 12, 2008 09:35 PM
vision1994
Oct 28, 2007 07:17 PM
