Speedometer plastic cover
Hello
Does anyone know if the plastic speedometer cover is removable? Mine has a crack on it and I'd like to replace if it's not too much hassle. Mine is a UK RHD, 2015 petrol estate. Would be helpful if anyone also knows the part number and/or has a trim removal guide for this area. Thanks |
I'm quite sure you can remove the clear lense once you remove the instrument cluster form the car. Ring your local Mazda part department for a quote.
This link is for the US market. You may be able to select the best match model / specs for your vehicle. https://www.onlinemazdaparts.com/a/M...S/5442440.html |
Spoke to my local dealer, and yes, it's removable. The part is quite cheap as well. I found a removal guide which isn't quite for my car but will be good enough. For the moment I'm leaving everything alone, but should the crack get any bigger, I'll have to replace it.
