Oil Pressure Light HELP!
Old May 2, 2014 | 03:35 PM
eleebid's Avatar
Default Oil Pressure Light HELP!
2005 Maxda 6S
Oil pressure light comes on when the motor warms up.
If I keep the revs at 2000 oil light stays off.
When warm @ idle light comes on.
My mechanic tested the pressure. It is 100 PSI at idle. Should be around 40 PSI.
Does the over pressure fool the sensor???
I have a restriction some where. But where?
Will a new oil pump fix this?
Any help greatley appreciated!
Thanks!
E
Old May 2, 2014 | 10:49 PM
tanprotege's Avatar
This is outside of my comfort zone.
I do not know if the oil light comes on when the pressure is too high or only if it is too low.
If there is a restriction somewhere it will cause oil starvation past that restriction. No good.
A few question: How many miles are on the engine? Has the oil been changed regularly? With the proper type of oil?
Here is a primer on the issue, that's all I can do for you now.
Automotive and Industrial Lubricants - Causes of High and Low Oil Pressure
Old May 3, 2014 | 07:45 AM
I would put in an oil cleaner like: Auto-Rx Plus Non-Toxic Sludge Remover and Cleaner for Engines and Transmissions
Old May 3, 2014 | 04:09 PM
keninn's Avatar
i would replace the oil pressure switch, probably a 10 buck part. they go bad all the time
Old May 3, 2014 | 10:13 PM
tanprotege's Avatar
keninn: I am glad you look over our shoulders.
Old May 8, 2014 | 01:21 PM
eleebid's Avatar
Default oil change and new filter fixed the problem
before spending hundreds or thousands
I changed the oil and filter
The problem went away.
My guess is the filter was clogging up
Thanks for the help.
E
Old May 9, 2014 | 05:52 AM
For peace of mind, install a good quality electric oil pressure gauge.
Tanzanite
Jul 18, 2014 06:24 AM
imjamesscott
Jun 3, 2014 08:56 PM
MattPanther
Dec 3, 2013 03:50 AM
race7820000
Mar 30, 2011 05:17 PM
