2014 6. Engine light/ tire pressure light Help!!
Old Dec 1, 2013 | 01:55 AM
MattPanther's Avatar
Default 2014 6. Engine light/ tire pressure light Help!!
So when i left my house no check engine light was on,drve to a friends house about 30 min away then went and parked at the mall, when i came out a few hours later the check engine light came on, i checked the fuse box and they are all good nothing loose i did push on them to make sure..
so any idea's what it could be? the engine light just stays solid. When i started the car all sounded fine driving it home everything seamed fine.
Also had on the way home the low tire pressure light come on got home check my tires all are good. was about a 10-15 min drive after the check tire light came on when i checked the tires. Now i do live in Canada and had winter tires installed at the Mazda dealer.
Old Dec 1, 2013 | 03:32 AM
What tyre pressure are you running?
Have you tried resetting the tyre pressure monitor?
How long ago were the tyres fitted?
Old Dec 1, 2013 | 06:44 AM
It's definitely warranty, regardless.
You'll have to take it back to dealer and demand no charge.
They'll have to retrieve code as well.
Old Dec 1, 2013 | 02:04 PM
What tyre pressure are you running? 34psi
Have you tried resetting the tyre pressure monitor? Nope not to sure how.
How long ago were the tyres fitted?have only been on the car for about 2 weeks
Old Dec 1, 2013 | 02:05 PM
Yeah thinking ill just take it to the dealer.. and it better be no charge the car is only 4-5 months old
Old Dec 2, 2013 | 05:57 AM
Read your owners manual and find out how to reset the tyre pressure monitor.
We don't have it in Australian spec Mazda 6's.
If it the same as a CX5 there will be a button beside the I-stop button. ( either to the left or right of the steering column. )
Old Dec 3, 2013 | 03:50 AM
So a update my check engine light and warming now has gone away no idea how that happened.. still going to call the dealer and take it in tho.
Tanzanite
Jul 18, 2014 06:24 AM
oakridger
Jan 13, 2013 07:01 AM
plaindi
Sep 16, 2008 04:19 PM
plaindi
Sep 16, 2008 04:07 PM
Krameryah
Jan 19, 2008 10:00 PM
