Mazda 6 - ODB Readings - emissions fail
Hi all. Have a 2008 mazda 6 that failed on emissions. Readings were miles off
Low Idle (700 rpm)
CO 5.96 Vol%
HC 271 ppm
High Idle (3000 rpm)
Lambda 0.81
CO 7.17 vol%
HC 350 ppm
Mechanic says it COULD just need a new oxygen sensor but for the age of the car and needing new brake pads he was leaning towards me scrapping the car but I love the car and hate to see waste. So wondering if anyone on here would be able to look at these odb readings and tell me if they think oxygen sensor should do the trick and then a bit of cataclean after might get me past the nct.
First MAF with two revs seems normal
https://imgur.com/BK7PCMi
Worried about the cat fail on that but not sure could that be sensor 2?
https://imgur.com/KmAlkAu
This is with a warmed up engine and multiple 3000 revs and nothing changes. I think its meant to be close to zero mA on sensor 1? and moving back to zero but this just stays at 6.35mA
Here is a list of all the readings at idle
https://imgur.com/hF6Mn6t
Then a list of all readings at 2000 RPM
https://imgur.com/ZLfqArO
If you need any more readings or info just ask and I'll post them
Thank you in advance to anyone willing to give their time to reply.
Low Idle (700 rpm)
CO 5.96 Vol%
HC 271 ppm
Lambda 0.81
CO 7.17 vol%
HC 350 ppm
