mazda 6 automatic gearbox oil change education/reset re learning procedure ?
Old Feb 5, 2024 | 05:40 AM
elfer's Avatar
Default mazda 6 automatic gearbox oil change education/reset re learning procedure ?
Good morning everybody, my car is 100000miles i plan to change automatic gearbox oil + filter, can i use aftermarket filter and original oil? Is it ok to use transmission gasket and filter from mahle or other brand from factory car came with glue.silicone.sealant? Is it really needed gearbox to be reset learned procedure after oil change how this can be made, with forscan and how or something else? Thank you.
Old Feb 5, 2024 | 11:28 AM
Originally Posted by elfer
Good morning everybody, my car is 100000miles i plan to change automatic gearbox oil + filter, can i use aftermarket filter and original oil? YES Is it ok to use transmission gasket and filter from mahle YES or other brand from factory car came with glue.silicone.sealant?NO Is it really needed gearbox to be reset learned procedure NO after oil change how this can be made, with forscan and how or something else? Thank you.
See bold color responses in your quote.
Use any ATF that is compatible with your year Mazda. See Castrol
And filter will work just fine
I highly recommend to use a gasket only and no sealer.
The relearn is not necessary and really would only need be done with other transmission services not a simple oil and filter change.
Old Feb 5, 2024 | 11:42 AM
elfer's Avatar
Hello, i have spoke with several repair shops they told me to use sealant only ? no gasket?
otherwise it will leak also on youtube i have found video where they use sealent only no gasket?
i am very confused
https://www.youtube.com/watch?v=kT2x...ature=youtu.be
how to make relearn are you familiar with that?
Old Feb 5, 2024 | 03:43 PM
i am very confused
If you already have advise then why did you come here and ask and then don't care for the answer because it does not meet your other information portals?
Ok well I am not them! and I don't use sealer on oil pans general transmission of engine gaskets ONLY because it is not user friendly and often necessitates more frequently than not a redoing because of leaks.
If you look around this forum you will find I have posted this information countless of times for members that are DIY and they all had success taking my advice. There is also a couple dozen pictures of this service I personally have done at least 4 times on my Mazda 3 at only 53k miles.
BTW These are not my initials in my name
ASE
Old Feb 5, 2024 | 03:50 PM
elfer's Avatar
ASE
I already have original mazda oil genuine and good quality german filter, but it comes with gasket, so i was thinking skipping sealant,
is it a must to change nuts and washers as well or only oil filter and gasket will be ok? i will use your advice i just need double confirmation i also in the past used gaskets but my cars was different and gaskets comes from factory its strange why mazda is using glue instead of proper rubber gasket? My mazda is 6
have you done mazda 6 are they sharing same gearbox 3 and 6?
i currently have issues with my gearbox , will changing oil and filter and adaption fix the issue, also how i can do that with forscan?
Old Feb 6, 2024 | 10:00 AM
You can find a few transmission and filter service on my thread that I show exactly how to do it.
Post #297- 301 is a better posting showing the gasket only application
Mazda3 Things I like to do - Mazda Forum - Mazda Enthusiast Forums
(please don't ask questions on that thread it is not a technical advise thread)
No you do not need new hardware.
Mazda like many auto manufactures over decades use sealer only as a cost savings over gasket's . Also the transmission is often not a routine service area and Mazda claims lifetime no service on some of their models. Which IMHO ridicules!
Old Feb 6, 2024 | 11:44 AM
elfer's Avatar
Ok, can you tell me how i can adapt the gearbox since mine have issues?
mehdi727
Oct 10, 2021 01:10 PM
marc515
Jul 12, 2009 03:23 PM
Froggman
Feb 14, 2009 12:55 PM
IvanLawrence
Oct 29, 2008 07:06 PM
jrm6012
Dec 1, 2007 09:24 AM
