Gear Stays in 3rd
Old Jun 14, 2009 | 06:26 PM
mastercjy's Avatar
Default Gear Stays in 3rd
I had to take my car to a mechanic to replace right engine motor mount, and about a couple of days later whenever I start up the car, the gear changes from 1st to 3rd then stays there. The check battery light is on too. Does anyone know what is causing this?
Old Jun 15, 2009 | 02:41 AM
oldeng's Avatar
Just worth checking. He may have left the engine block electrical ground off, or connected it improperly. If the PCM sees things with the engine are seriously out of whack, it will default to limp mode as a safe get you home configuration, which is why your gears "misbehave". Go back to your guy (who by the way may have deep-sixed your alternator voltage regulator too, if it is a main ground connection issue).
Old Jun 22, 2009 | 09:50 AM
nyinthabuilding05's Avatar
do you have an auto transmission? if you replaced a motor mount, ANY motor mount for that matter, you dont have to touch any sensors or the alternator.
do u have a 6s or 6i?
donny b
Jun 20, 2007 08:23 PM
blayzegirl
Mar 13, 2007 12:20 AM
kupiec79
Jan 26, 2007 08:58 PM
boober
Aug 8, 2006 02:50 AM
the_gray_mazda6
Nov 24, 2005 01:56 AM
